Sleeper, the problem with those replica blocks is that they dont accurately reproduce the main bearing saddles. Without those, you don't have an accurately identifiable crankshaft centerline. Since that is the reference point used to locate block to pump, the plastic blocks aren't terribly useful. I spent a bit of time trying to come up with a simple way to make one work. Ended up making fixture to use a borrowed bare block.
Here is another angle of the fixture used by Bigamist. He can correct me if I'm wrong , but I believe that is Jim Brock's fixture. Jim has mentioned willingness to rent it out. Call him at Cyclone Marine in Pacoima, Ca or send him a PM.
I see what you mean. As far as the rigging for a car you just bolt a belhousing or tranny to them. Got it.Sleeper, the problem with those replica blocks is that they dont accurately reproduce the main bearing saddles.IMG]
Oldsquirt, am I correct with the idea that the bottom of the plates on the fixture represent the Main bearing register and not the pan rail as the crankshaft CL is taken at the point of the register?Sleeper, the problem with those replica blocks is that they dont accurately reproduce the main bearing saddles. Without those, you don't have an accurately identifiable crankshaft centerline. Since that is the reference point used to locate block to pump, the plastic blocks aren't terribly useful. I spent a bit of time trying to come up with a simple way to make one work. Ended up making fixture to use a borrowed bare block.
Jim did you make that ? It is a nice piece of equiptment. Reminds me of fixtures that Kaiser had at Alpha in the old days.3/8 " was milled off the front and rear of a block, the 3/8 end plates were bolted to the block, the tube in the center is the crank, they were welded together, and another smaller tube with a set bolt and spline were slid inside to ajust to your drive shaft length, measure your drive shaft, set length, bolt your mounts to the end plates, slide it on the pump and drill as easy as 1 2 3
The fitting/pipe belongs to CS, it's used for getting the proper alignment of the block.Busby ,Could You please explain how You'r fixture works.
The pipe or tube representing the crankshaft, do you slide the block foreward and aft to determine the engine placement?
Do You have a part of a driveline welded on the pump end of the pipe?
How do you determine the engine side end of the drive line without the flexplate in place. is ti just by measurement?
What type of spacer did You use in the crank journals ,to keep the pipe centered?
Is there any thing on the front end of the pipe?
And Most importantly What points on the block do You use to measure up the plates for hieght/ Do You use the CL of the crank and cam and the main bearing registers to define the botom edge of the plates and the mounting holes?
Can You please elaberate on how this is used to fab the engine plates? I understand the pipe keeps the engine in line with the pump, But where do You go from there to build the engine plates? Again sorry for all the questions, And I really appreciate the answers....Hal
Oldsquirt I have studied the drawing but I do not see what is missing.BTW, I was the one who posted that diagram many years ago. Have you noticed the critical info that is missing from it?
Busby;The fitting/pipe belongs to CS, it's used for getting the proper alignment of the block.
Wood bushings were made to slide over the pipe and go into the main journals.
Side to side it all measurments, as is the entire project.
Where the block goes is based off of how far from the transom you want it. Once you have that set, the block is set on wood & remove the chains.
Then you make your templates for the plates.
you can zero the digital level to the boat, do not zero to the stringers as they could be off a little and even a little off makes it look way off.Busby;
I see You are using a level on the block. Should the boat be level,across the stringers, when seting up to measure for the plates?....Hal
What boat ?Hate to do this, but let's not talk about my boat anymore please.
exactlyWhat boat ?bulb
S CP![]()
DAMN! You have a boat? Must be R/C (really Crappy) huh?Hate to do this, but let's not talk about my boat anymore please.
Yea I think I figured it out after useing it all day. There is no reference to crank cl, side to side for the holes and there is no reference at all to the right upper hole at the bottomHal, don't "over think" it.What is important is the location of mounting holes on the end plates relative to crank centerline. If you want details on that fixture just give Jim a call....or maybe he will happen to see this thread.
