In my opinion, only the fastest drag and circle boats gain any (small) benefit from this and I'll bet that none of the fastest run flex plates but rather light weight steel or aluminum flywheels. The trade off with a flex plate is not worth the loss of reliability in my opinion, especially in a lake boat, yours may differ.
Shirl Dickey
CJ60
If you are ever planning to run a v drive circle boat, you quickly learn that there is more to the weight of the wheel than acceleration. As much energy that it takes to spin the wheel up, its carrying when it comes to slowing it down. One trip into the turn with a 24 lb flywheel verses a lightened alum wheel will point that out to FAST. The weight the wheel will kill your time on BOTH sides of the turn.
I agree, CHEAP SFI stamped flex plates are a disaster in any boat. There is nothing hooked to the plate to arrest the harmonics and ring like a bell in operation.
There are only 2 flex plates I will consider running. The Maeziere billet, and the JW "The Wheel". EVERYTHING else is junk looking to crack. The stamping process puts stress the wheel forming the damn curves that are useless in boat wheel, and the hole ALL have a sharp ass edge on one side and radius on the other from the stamping. EVERY HOLE!!! They all act as stress risers if they are addressed.
I prefer an aluminum wheel. But even the newest aluminum are failure prone because they are cut from bullet with the grain structure all wrong.
If its cut from plate, the grain run across the wheel in one direction, and it cannot possibly right in all directions. If its cut from bar stock, the grain runs the thickness of the wheel, which is probably worse. I have seen the center tear of more than few billet aluminum wheels. That's why I run a PTO on the wheel instead of just bolting the POS to cranks. It clamps the wheel to the crank and helps support the center better.
The VERY BEST aluminum wheels are the old forged pieces made by Wilcap, M/T, Weber etc in the days gone by. Re-enforced ribs on the backside, and vastly superior grain structure. When I see one on Ebay for the right price, I snap it up.
