so i have an eliminator with a 350 chevy to an alpha one, the motor in the boat was the original from 88, which i believe is the 1 peice rear main? i am plucking this motor out for the seaso and trying to replace it with a 1975 small block, here is my issue... the flywheel appears to be a 14091599n, which the only thing i can find online is a 14' 168 tooth flywheel, the center hole that sits over the crank has to small of a diamiter to fit the new (older) block, the diameter of the center hole on my flywheel is 2" yet needs to be 2.5", any suggestions? cross reference, something?
