1 - 2 of 2 Posts
This system includes the Ford 302 pro billet distributor, MSD Street Fire Ignition box, MSD blaster 2 coil and 8.5mm 135 degree BLUE spark plug wires. THIS KIT WILL FIT FORD 289-302
Distributor specs:
Maintenance free magnetic pickup
sealed ball bearings
sintered bushing
hardened steel shaft
tuned for optimal performances for Ford Small and Big Block V8 engines
MSD STREET FIRE IGNITION BOX SPECS:
built in rev limiter to protect your engine from overrev damage
multiple spark discharge delivers high powered multiple sparks to improve combustion and performance
full voltage at high RPM increases top end pull
installs to 8 cylinder engines
MSD Blaster 2 coil specs:
Manufacturer's Part Number 8202
Coil Wire Attachment Female/Socket
Primary Resistance 0.700 ohms
Coil Internal Construction Oil-filled
Turns Ratio 100:1
Maximum Voltage 45,000 V
Secondary Resistance 4.70K ohms
Inductance 8.0 mH
Peak Current 140 mA
Spark Duration 350 uS
Diameter (in) 2.125 in.
Height (in) 6.000 in.
MSD Blaster coils put out 45,000 V, which are 15,000 more than stock. They also have an oil-filled metal canister and will fit stock mounting brackets.
THESE ARE A UNIVERSAL FIT WIRE, SO YOU WILL NEED TO CUT THEM TO LENGTH AND CRIMP THE DISTRIBUTOR ENDS ON TO THE WIRES. THE PLUG END OF THE WIRE IS ALREADY FINISHED WITH A 135 DEGREE BOOT.
HERE ARE SOME FEATURES OF THE MEGAFIRE WIRES:
• Super low 250 ohm per ft. resistance
• Pure silicone heavy duty boots
• 100% Silicone 8.5mm outer jacket, heat rated to 575° F.
• Kevlar Center Core for strength.
• Fiberglass braid reinforcement
Selling price: $300.00 shipped
If you are interested please fill free to email me at [email protected] or call/text @ 510-377-7567
1 - 2 of 2 Posts
