1 - 20 of 31 Posts
I'm considering purchase of a used '06 tow vehicle e/w 6.0L Turbo Diesel with 72k miles. Anybody have towing experience with this setup? It seems that later models are now 6.4Ls. Thanks in advance.
good luck keeping it on the road and outta the shop:D if you buy it, upgrade the egr cooler immediately!
"Try it Now!"
I don't have a 6.0, from what i hear, the later years (like yours) are a better than the original 03' ish ones. There are fixes for the inherent problems with them. Where are you located? I can refer you to a couple of great places to fix those things if you're near so cali.
The HMFIC
my 06
i love my 06 it has never let me down i tow my 23 ft boat and i also to a 37ft 5th wheel im programmed intake exhaust lifted 35 in tires the whole shabang. i have had my problems but its only cause i hard on my truck. use it like a man and with 50000 miles on it its still under warranty so i dont care yet everything that is supposed to fail has already failed and i have all the upgraded fixes so im good to go now. you wont be disappionted. there are a lot of ford haters out there but im ok with that ive go so much power to the wheels that i cant hear the shit talking through the plume of black smoke i leave them in. unless its a built cummins from 03 04. that motor is the shit and im in the process of saving money to drop that motor into my ford. i will be destroking my ford soon enough. the ultimate truck would be ford exterior chevy interior ford 4x4 system allison tranny and a cummins 24valve common rail. if someone built this I'd buy in a second:)devil
Go to Powerstrokenation.com forums, we call the 6.0 the 6 uh-oh there, They just dont have the reliability of the 7.3. The 6.4 has emmesions problems, you are lucky to get 12 mpg towing anything. I get fifteen towing seven head of horses, 16 towing my boat, and 20 empty in my 7.3
I have to agree with that. I also like the six door F650 with a tricked-out interior, a built Cummins Common Rail(say 700hp/1400tq) and a Kelderman Air Ride suspension to smooth out the road.
www.f650pickups.com
I had a 2006 6.0 4x4 crew cab F250 - I sold it last year with about 65,000 miles on it, mostly towing boat (25 howard), car trailer (9,000 lbls) or toy box (11,000 lbs). I put on a Donahue Racing 4" lift and 35" tires and lost 2 mpg. Then I added the complete Banks system (Big Hoss Bundle) and lost another mpg.
If you leave the truck stock it is pretty bullet proof. There are a number of issues that do occur like the egr plugging, the turbo vanes sticking, oil build up in the turbo, that leads to the turbo hose slipping off, blown head gaskets are common on trucks with any mods (ARP head bolts is the common cure.).
I this months issue (July 2009) of Diesel Power they have an article - "Every 6.0l powerstroke problem solved" - they pretty much hit them all. I would definately get a copy and read up before you buy.
The truck is a nice truck but is built to withstand stock power only. But it is so nice to have the extra power.
I had a 2000 7.3L before for 88K miles and had not 1 problem, I wish I would have kept that truck!
I now have a 2008 Duramax with Alison 6 spd - love this truck except for the DPF which kills the mileage. But great power compared to the Ford.
Good luck finding the right truck, definately some great deals to be had.
JCM
I just un-plugged the EGR valve and never had a problem after on my 04. The delete kit not worth the money when un-plugging one wire does same thing! Other than that its a good engine mine had just over 200K when it was sold.
The HMFIC
did unpluging this wire give you a check engine light???
Best ever
i have an 03 6.0 and it has over 500,000 miles and run like new. only had to have oil pan fixed once from a hole that happened when blew a tire. NO Problem.
Renegade jet
I have a 2006 6.0 diesel and I like it. I blew the head gaskets a few months ago and bought the arp studs and the dealer did the work under warranty. :) I also was able to talk the tech into throwing in the egr delete in the process, should be good to go now. The nice thing about 07 and older trucks is you can put a tune on them and pull it out and take the truck in for service.
Ralphs club member
Google 6.0 powerstroke......start reading and cringing ! Serously, i know some people have "good" ones....but if you get one like most people, AND have no warranty.....LOOK OUT! Any truck that requires the whole cab to be removed from the frame by hoist, to change the headgaskets (which are problamatic to that engine) is a no go in my book. Id get a 03 and down 7.3, or roll the dice with the new 6.4 before buying a used 6.0. Know way to many people personally that have experienced all the carnage you read about with those puppies...
I have six units with the 6.0, not including my personal. Mileage ranges from 50k to 150k. All are minimum 10,000lbs loaded all the time. The only issues any have had was a leaky injector. That happened on two trucks, but both were replaced under warranty. Most of the issues were when the motor was first released. I also have 4 7.3 units. My personal preference was my old 7.3 with the six speed. The 6.0 I have now does have a little better power in stock trim, and its quieter. Almost any of the problems I've seen with any of the big three diesels come from guys trying to turn a 7k pound truck into a hotrod.
One other thing. Ford was offering an extended warranty to 200k if memory serves me for about 2k. That's cheap insurance on the powertrain.
Inland Empire-Big River
I have an 04 6.0 F-350 with 60k. Its lived its life towing my 40' toyhauler.
The first 20k miles it had its own parking spot at the dealer. I happened to be the baseline for Ford's learning curve I guess:)sphss
Since fixing all the kinks its since been a great truck. I too unplugged the EGR and havent had an issue since but I do have a "check engine" light on. If I pull the neg off the battery it tends to go away for a while, but if I do end up having an issue I probably wont realize it until its to late.
I've only added Exhaust & intake. You shouldnt have issues with the later years, most of the horror stories are from mid 03 thru 04.
Ironically I'm still a fan and love the truck.
i wouldnt hesitate to buy it.I have an 05 that had the 6.0l in it til someone convinced me to do a cummins conversion.:mad:An egr delete from elite diesel, 4" turbo back exhaust, and a cold air intake youll have a very reliable rig that will get good milage with plenty of hp.If youre gunna tune it go with SCT.Everyone talks these motors down but with a few simple mods and a good maintenence schedual they will run forever.Just my $.02.
Ralphs club member
All you guys doing the EGR bypass....if you live in California, you will be smogging your diesel within the next 2 years. Two of my buddies have already had to do theirs, so make sure that whatever you do is reversable so you can pass smog when the time comes. Crazy huh? Guess my CAT will be going back on when the time comes, but thats all ive removed from my 03 cummins
I hate to recomend Banks,but they are the only aftermarket co. i know of CARB certified.They might have other alternatives.
1 - 20 of 31 Posts
