This is a 496 built with:
4 bolt main standard deck block, freshly bored, honed and detailed, new Durabond cam bearings installed.
New 4340 imported forged 4.250" stroke crank, SCAT H beam rods, forged pistons, Clevite "H" series rod and main bearings, moly rings, new harmonic balancer and flexplate.
Precision balanced.
Assembled including bearing clearances measured, crank thrust set.
$3800
I also have a similar "street" 496 available, 2 bolt block, new cast crank, new I beam rods, new Hypereutectic pistons, Clevite "P" bearings, same quality machine work, balancing and assembly, only $2550.
Still located in Southern California.
Precision balanced.
$3800
