1 - 2 of 2 Posts
I have a fresh built 605" BBC by Mike Miller Racing Engines. All good parts. The motor has Dyno Time and 1 weekend at the river on it. Motor built to run on VP 110 out of the pump so you can cruise around the river with it or haul ass. Made 1,160-hp on motor plus it has a new Edelbrock Fogger system plumbed by B1 Racing. Engine specs: Iron Dart M Block, 12 Degree Profiler Cyl Heads, Profiler intake manifold ported and polished, Gary Williams Carbs, Jesel Shaft Rockers, Isky Offset lifters, Jesel Belt Drive, Callies Magnum Crank, Oliver Rods, CP Pistons, Williams Pan, Moroso Vacuum Pump, Star Machine Mandrel Assy, External Belt Drive Oil Pump, Crank Trigger, 55mm Comp Roller Cam & Manton Push Rods.
Motor comes complete minus headers, fuel pressure regulator, & scoop tray......$27,000
Call or text for more info.
Wes Wise
619-777-3207
San Diego
1 - 2 of 2 Posts
