Currently have a inline pump but it has problems keeping up at high throttle on long runs. Used to run a holley red till the rotor in the motor (not the rotor in the pump) went bad on me. I like the fact that I can hear the fuel pump running when I turn on the key and can hear the bowls fill if they are part empty. Before I just go back to a holley red is there some advantage to a mechanical fuel pump (ie higher pressure and flow) and what are most of you running and why?
