Looking for ideas on fabricating new pick up tubes for my rig. I have a tank that is not removable and I need two pick up tubes installed. I will be welding two #8 an nipples two a .250 oval plate that will bolt down to the top of the tank using a gasket to seal the deal up. I don't know how to make or what to use as tubes. The plate with fittings will be at the far right of the tank and the tubes need to be in the center as the tank has a sump in the middle. Any suggestions will be appreciated. Thanks SJ
