I recently purchased an electric fuel pump that came with a seperate regulator. Looking for some install pics so I can get some ideas. Thanks in advance.
With bypass or without?
Living in a cage of fear
This is a Blue pump and the 2 port, NON-bypass reg. that comes with the blue pump.
I have a #8 line feeding it, with 2ea. #6 lines out to 2 660's. The PSI gauge is on one side of the reg.
I now have switched to 2ea. 750 Holleys with dual feed inlets. So will post up a pic of that set up today sometime.
It now has a single #8 out of one side of the regulator with a PSI gauge, to a fuel block with 4 #6 lines to the carbs.
I will get a pic tonight but I mounted the regulator right off my fuel pump :D
