ok i know this has been asked before but here i go, again...i have a 392 hemi in my 70 raysoncraft i changed from hilborn stack injectors to 2x 750 edlebrock carbs just for simplicity reasons, 1/15 gears 11x15 prop 450 hp no biggie so far except i run out of gas after 10 seconds at full throttle i let it idle down it fills back up off i go as long as i dont go full trottle ...i have a carter rotary pump 75 gph mallorey fuel water seperator #6 feed lines ,do you think the pump is to small ??? maybe a holley blue label 120gph???to keep up
