i installed a set of hardin marine gauges and everything works with the exception of the fuel level. i have it going from the gauge to a 2 way switch, then to the tank sender. the base of the sender is then grounded to the tank fill and then to the ground on the battery.
is this wiring correct and also is there ANY way to test the senders with a meter before i go and purchase new ones that i might not need?
