Well I thought I would give it a try to ceramic coat my boat and it turned into a nightmare.
So I started polishing about half the boat before I noticed these little pin holes everywhere FYI GUYS DONT BE STUPID LIKE ME LESSON LEARN ALWAYS DO A TEST SPOT IN A GOOD AREA THAT NOBODY CAN SEE". So I stopped what I was doing and went back to the detail store they told me I needed a heavier grit and those pin holes will go away. I tried a spot only to see it got worse!! I already did some research and found that this could be that the GEL was applied wrong and got air bubbles in it and there's no way of fixing it. So iam pleading with you guys praying there a solution to atleast make it better. Thanks all for responding.
