1 - 7 of 7 Posts
Islander Transient
OK, here's an odd one. Does anyone have any idea what the compression should be in a generator engine?
Model: Yamaha YG2800i
Engine size 171 cc
I ran a compression test and it was about 50 PSI. This seems incredibly low as most engines I have tested are closer to 150+ PSI. But I thought that due to the smaller displacement, fact that it's not a high compression engine and it's pull start rather than electric, that the compression might be lower. But 50 seems too low.
Any ideas???
Engine junkie
The unit most likely has a decompression mechanism used for start up, once fired the decompression mechanism disengages.
To answer the question about compression, it takes a minimum of 90psi for combustion to "correctly" take place.
You may want to do a valve adjustment if not already done, this may clear up some issues too.
Islander Transient
Thanks, yes it does have a decompression mechanism and the genny runs fine, although it's louder than I would expect it to be. I do valve adjustments once a year and an oil change twice a season. Just wondering what the correct reading should be. The genny is 6 years old and for the past 3 years I've used it alot so I'm trying to determine if it's time to hone the cylinder and put some new rings in.
Engine junkie
If its not smoking, showing signs of oil fouling or excessive carbon build up on the plug then run it.
You can do a leak down test on the cylinder, that will give you better feedback than a compression test.
1 - 7 of 7 Posts
