More than one...
What "value" or resistance does Accel recommend for their coil. Are you using Accel's ballast resistor?... The ballast resistor is used to reduce voltage to the coil. I think it was originally used to prolong "point" life, I'm not sure why the more modern systems even need one.... I know there were 9 volt coils that didn't need one, and I think GM used a "resistance wire" to accomplish the same thing.. Again, does Accel recommend a particular part number for their coil?? OR, are you using what Pertronix recommends? AND, are they different?
Ray
There ts more than one ballast resistor. (maybe 6 different ones available at your neighborhood parts store).
Ray
