Steering wheel and seat are for mock-up purposes!!
The following are for those who got a kick out of the size of my engine stand, So a tour is in order
Paint booth
Good pic of engine stand, yes that is a blue 55 gal drum next to it.
This is more the size of engine for that stand and I used a full size coffee can for reference!
I don't use cherry picks. These work better!!
A press is always handy too. 20 ton air operated:)devil
Those pics were just for fun:)devil
Discussion Starter · #6 ·
And disallowed by most sanctioning bodies.........Not because of rubber, because of glass...........Ray
PS: Very nice install..........I would however, do away with the house plumbing components unless you can hide them down low somewhere......
Thanks:D
The fab shop is making me a complete stainless steel setup all welded and nice looking but this one will have to work until winter!!
I am already planning on getting a set of Patriot Alum. rect. port head heads and headers this winter!!:)devil I just want a month or so in the water so this will have to work for now.
I also saw a flanged pipe setup that bolts onto were the water pump goes, instead of the two plates and fitting. So I am having the fab shop make me that as well.
So I figure once I change the plumbing around for the headers and pipe I will then spend the money on the stainless braided hose and nicer fittings!! I will say I like the shrink clamps that gates hose makes they look bertter then hose clamps IMO.
So what fuel filter would you guys suggest? and is there anything else I could change around to help. Any feed back would be great!! Thanks
