1 - 13 of 13 Posts
· renegade1
Hey guys, when I put the boat in revese it sometimes gets stuck there. I have to go to the back and pull the cup back into foward manually, it really gets jambed but not everytime. Can I grease it somehow, or is there a common problem that I can fix. Thanks
· Sit N' Spin
Mine did the same exact thing after having the nozzle powder coated. Kinda the same thing bajadad had to do, except I filed some of the powdercoat off of the end of the nozzle to clearance it.
· Registered
Could be "sand locking" a common problem in shallow waters when enough grit, silt and sand gets into all the reverse bucket points it can jam up a bucket something feirce. Its actually a major reason why alot of folks here either dont run reverse or at least only use it as a last resort. You get stuck in reverse in a fast flowing section of river and you can be in big trouble.
Other than whats been suggested here already if it is just sand locking alot of guys here will drill and tap the bucket with a small single bolt and attach a small length of coated cable which they attach to another part of the transom. This gives you something firm to yank up on the bucket. Its happened to me a few times and it feels like something mechanical is holding it back it can be so stuck, you are nearly 100% convinced the cable is pooched, but its just sand etc
Cheers
· Registered
Cheers
what he said:)devil
· lol, right.....
Cheers
I had that shit happen to me awhile back. At first I was like, "F*ck it, I'll just back my way back to the ramp." Uh-uh, that wasn't happening. :p Got my son-in-law to tow us back to the ramp. Got it on the trailer, went back there & lightly yanked the bucket upwards & 2 small rocks/pebbles fell out. :rolleyes: Thats all it was...
· Living in a cage of fear
If nothing at the bucket helps, try looking at the cable at the lever. Mine was not lined up right and in a panic reverse (different story!) it bent the cable end right at the lever. It would then stick in the cable housing when trying to push it forward.
I just straightened the end with two wrenches and re-mounted it correctly.
· Registered
this very thing happened to me, only it was due to my kid tripping when getting into the boat and sat on the lever. just had to straighten it again.
1 - 13 of 13 Posts
