Where do you guys mount the antenna's for in dash GPS speedometer's?
Like all of us have carbon fiber hulls. LMAO!!Mount them under the dash board, they must remain pointed up for the best signal reception. If your hull is carbon fiber reinforced, this will weaken the signal going thru the hull. Try a few different areas, to find the best suited location, there is no need to mount them on the top of the deck.
Where do you get one that has a digital read out so I don't have to drill another hole?Where do you guys mount the antenna's for in dash GPS speedometer's?
I have no idea. How is it being digital going to prevent drilling holes?Where do you get one that has a digital read out so I don't have to drill another hole?
Oh sh!t, you mean you don't have a carbon fiber hull? That's cool, old school is good too.Like all of us have carbon fiber hulls. LMAO!!hil
hil
hil
Reality
Well, maybe not as big a hole.Right on! Thanks for the replies.devil
total over kill. good manMy boat has a bulkhead up front. I took a sheet of 1/8" aluminum sheet, put two 45* bends in it, then welded a piece of 3/16" flat bar and welded it on the angle for support. Bolted that to the bulkhead and black RTV'd the antennas to the top, facing up.
