1 - 20 of 20 Posts
I hope a few of the head gurus answer this. When the heads (290) were set up all was well, now I have a valve guide holding a valve alittle tight? Bronze wall (not inserts). I have never seen a bronze guide tighten up like this. The valve is straight. IDEAS????? M
Oil cooked and cokes the guide?
My temp never gets that high, oil or water. I just got home from my nights work and I will measure both and random samples to narrow down were the issue is! Thanks for the response. For what its worth it is an exhaust valve/guide that is hanging up! M
Come-on gn-7. I was hoping for your'e opinion on this. We may argue about ring gaps and stuff but PLEASE don't take it personal:)devil I value alot of what you post and what's your'e thought? Never a problem for probably 40 hrs run time and now 1 valve hanging up:bangmyhead:. M
Boat Nut
Stainless valve? Inconel would be better, were the guides reamed to size after install? My brad new heads were taken apart, guides were reamed, and new Ferera inconel exhaust valves installed. The exhaust can hang up if they get hot, even worse if the engine suffers from reversion.
Old...how are you checking your guide clearance? Then only accurate way to check guide clearancess is with the proper bore gauges and a C mic that reads in tenths. Bronze guides will definitely grab abvalve if too tight...they're no less prone to this than anything else. You also need to make sure you're running chrome stems. Marine apps...absolute min. 0015 intakes, .0017 ex. Blower apps, .0019-.002 ex. I've never been able top ream a guide acurately ane be done with it. It always requires honing for the final fit.
When you say "290", what 290 are you talking about?
Thanks for the responses guys! Steel when I said 290 that was the cast heads I am running, with alot of work done. The valve guide tightened up at the last 1/2 inch in the combustion chamber, so it could be heat related? When they were put together every thing was fine for quite awhile. I am running good stem seals and now thinking of loosing them on the exhaust side only. M
Personally I don't run exhaust seals on fresh guides. At the first freshen up, it depends on application.
Now, how were the guides sized? Meaning were they broached (not if thick walls), reamed, or honed with a sunnen guide hone? And with SC... I use a Sunnen gauge. It is fast but also takes a little practice.
The failure I had with the guys engine was with used valves and some taper in the stem (like .0002")
I am not a fan of reaming for tons of reasons. Honing takes some skill to get them straight. Not rocket science, but not tear down guy easy either.
Wags
Been alittle busy a busy with the races at Long Beach with my own issues:mad:
I don't get into valve clearances and seat width much. I leave that to the head gurus. But what caused it to tighten, thats hard to say. More curious why you say its in the last half inch on the chamber side. Like Steel said, measuring guide clearances accurately take some specialized measuring tools that most us do not have, and have little use for to justify the cost. Not to say you couldn't see it was tighter in one area using nothing more than a ball gauge, just hard to tell the exact size, just that its tighter.
I would think galling the guide could tighten one up in a given area, but that would be pretty easy to see.
Never seen one tighten up that wasn't damaged, but then I haven't seen everything.
Discussion Starter #12
Thanks gn7. I have the gauges and mic's. I have pulled both heads and will recheck clearances to see if it is typical through-out the exhaust side. if so I am going to loose the seals on that side only. I have a strong idea it is heat related with a touch of dry guide. Thanks again guys, I think I over thought the obvious:)sphss Mark
Boat Nut
Old Guy, when I had my heads done, the builder popped off the springs when I dropped them off, and proceeded to empty the head. He had a full set of go-nogo gauges for the guides.
Discussion Starter #14 (Edited)
Sleek, I have a set of ball-snap gauges down to 1/4 inch. I am going to recheck the person who set up these heads and hone to work proper. on reassemble I will be loosing the exhaust seals. On a qwik check about an hour ago, the guides have a slight taper at the last LOWER portion! So now its time to dissassemble both and fix with a hone. I wish I had the old head bench from years ago but now it will be work with what I have. If this were a race deal I would be cutting down the guide and blending, but its just a budget project and we will see! M
Good luck. It is easy to hone a taper in guides. Especially solid (thick wall) guides. They are hard as hell to hone. (with stones) They hone beautifully with diamond abrasive. I have 2 grits of diamond for thick wall. But if you don't overstroke enough, or have a taper in the stone... well, tapered guides.
I was doing a set of big chief heads with new guides and spend the 80 each instead of taking a week to hone them all.
SOFT MY ASS! HA
Wags
Discussion Starter #16
Okay here we go on the find! 5 out of 8 exhaust valves had a seize problem at the last 1/2 inch of travel in the bronze-silicone guides. So I honed and pulled the stem seals on the exhaust side only. The intake valves were perfect on both heads so I did a qwik check and reassembled. The only reason I can come up with for the small valve side is lack of lubrication and being the hotter valve. They definetly showed scoreing at both the valve and guide. Just for reference for all that chimed in here. I truly appreciate the input!!!!M
Discussion Starter #17
SOFT MY ASS! HA
Wags
Yeah wags I agree they didn't give up to easy. With a few qwik strokes with hone it was like tease me some more! So I kicked it up a notch and got my way. I was stroking the damaged area only and got a straight guide. Basically I was taking out the galled area only! M
Chances are the guides were reasonably straight to start with, but the galling tightened them up in the area that hangs into the port. Probably a little tight to start with and the galling just tightened them up to the point of sticking.
We have always ran seals even on the exhaust and never had issues YET!, but I know of plenty that do not run seals on the exhaust and they work just fine, with maybe a little puff on start up from oil running down the stem when shut off. I even seen more than a few blown deals run without intake seals with nothing more than a slight haze at idle.
Thank goodness you caught it before you knocked a valve head off. :)devil Its way to easy to do with sticky exhaust valves.
Discussion Starter #19
At this point gn7 I can deal with alittle smoke on fire up or even a taste at wot. But with the bottom end I am running the last thing I want to do is drop a tulip and kill a cylinder for life. It's all stock below the heads and have this sick desire to see how much I can get out of it before deciding to build a real bottom end for the cam and top end resting there. M
1 - 20 of 20 Posts
