They are very nice hull, have a friend and his is in the triple digits. It would be my choice, there fast hulls, and still river friendly.
I would have to agree on thisyou can get to 100 with 650 hp easy enough
I have an 18, there are lots of 18's out thereIs there many 18' hulls out there? I have one and seems like all the ones I run into are 19'?
There sure aren't many of those running around. The only CP GW I've ever seen run 100 with even anything close to only 650 hp was Segni's (Blue Bomber) Built 468 maybe 675 hp it ran 105 off the Nos. Light boat less than 550 lbs and don't even think about walking across the bow.I would have to agree on this![]()
Doesn't any one ever keep track of records? I m not Joe blow, but my 18' cp 460" chevrolet still holds the ski jet record (sorry Ron Segni) and the comp jet record, both et and mph. Best pass 8.64 et at 121 mph. Hope this sets the record straight.There sure aren't many of those running around. The only CP GW I've ever seen run 100 with even anything close to only 650 hp was Segni's (Blue Bomber) Built 468 maybe 675 hp it ran 105 off the Nos. Light boat less than 550 lbs and don't even think about walking across the bow.
There are a few guy here that know the boat I think Ron won 6 Championships with it? It was dialed in and he had a shit load of time in it to do it. I'd like to see a 19' GW "Lake" boat run 100 with 650 HP. Not saying it can't be done but knowing what Segni did to get his to do what he did I don't see Joe Blow making it happen.
Sleeper CP![]()
I don't recall mentioning any recordsDoesn't any one ever keep track of records? I m not Joe blow, but my 18' cp 460" chevrolet still holds the ski jet record (sorry Ron Segni) and the comp jet record, both et and mph. Best pass 8.64 et at 121 mph. Hope this sets the record straight.
I'll take you for a ride in one once I get it rigged.Curious, how common would it be for Joe Blow river racer to build a 650 hp 100 mph Jet ?(regardless of GW or not) from my experience not very common.
Sincerely,
Joe Blow
I'll take you up on that. You're saying 100 mph with 650 HP lake boatI'll take you for a ride in one once I get it rigged.
Sincerely,
Joe Blow
No thoughts on my post??? Or am I a thread ender????
Sorry I live in Norcalhand
Only (suggestion).......92 at what rpm ? and where do you think the engine makes it power? I'd bet you're making more that 650 HP with that engine. What do you think?My TX-19 Condor runs 92 without NOS. (NOS is there, 100 on each carb), 520 lbs hull with intake, gauges and steering. 468 BBC,12.8-1 comp, Merlin 345 heads, 715 lift, solid roller, tunnel ram, 850 DP. Dominator housing, AMT Bowl, Aggressor Bronze "B" imp, 2* back cut shoe, 3.5* ride plate. Engine has never been dyno'd.
I have done nothing as far as set-up since it went back together. I feel I have a lot to gain with some set-up work. I want the "Bitch" to be quick, not a lot faster. Any suggestions??
I tryHAHA! i love it, thats badass busby!
