Im got a problem with my trailer set up. the landings around here have cement blocks like railroad ties and when I pull my boat out the whole thing bounces and I think or I know its going to rip the eye right out of the hull and it takes at least 2/3 people to get it out of the water and setting right on the trailer. when I got the boat it had a stationary setup and I would have to lift the bow up to hook it in and you had to be on the ball or it would take a chunk out of the bow. not good so I fab this up but its still sucks and I cant seam to keep the boat straight and its putting alot of stress on the bow eye sooner or later its going to rip it out. I dont know if i should build a tower with a rubber v block and a crank set up or try to fab this deal again a little different or what??? also how far should the transom be forward of the end of the bunks? if its to far back will it cause hook to the bottom? this is my first jet boat so Im no pro!! I grew up on a lake and loaded tons of boat and its never been this hard. every time we load up I think it going to be a bad deal the eye is going to come out and there we sit stuck at the landing with a big hole in my boat and no way to get it off the water. What did I do wrong??? some pics would help of some setups if anyone can help THANKS
