1 - 11 of 11 Posts
Or Seth, either one
Do you guys use, or would you use a sealant on a Fel-Pro MLS style head gasket? Or just put it on dry?
Stock block and heads, ARP head bolts
Thanks Guys
Ditto!!
If the tabs are short by the lifter valley then use RTV there. Basically follow the installation instructions if you have them!!
Or Seth, either one
Not black, it's this one
Part Number: FEL-8180PT-2
Bore (in): 4.370 in.
Bore (mm): 110.998mm
Gasket Material: PermaTorqueMLS
Compressed Thickness (in): 0.039 in.
Compressed Volume (cc): 9.700cc
Lock Wire: No
Quantity: Sold individually.
Head Gasket, PermaTorqueMLS, 4.370 in. Bore, .039 in. Compressed Thickness, Chevy, 396-454
Still install dry?
that IS NOT a MLS gasket. Godbless Summit. That is a bottom rung rebuild gasket that I cannot recommend for any performance engine, and certainly not a marine engine. But if you insist on useing it, no you still do not use anything on a composition type gasket. MAKE SURE THE DECK SURFACES ARE SPOTLESS
http://store.summitracing.com/partdetail.asp?part=MRG-3156G&autoview=sku
this is a stainless steel MLS marine gasket
Or Seth, either one
If it blows again, I'll step up to something better next time. Will I need to re-torque the heads with this one? If so, when?
Thanks guys you rock :)devil
Blows again???? Why would you want to go through all this trouble again, plus risking the motor with the possiblity of water getting into it? Not trying to be too harsh, but a decent head gasket is only 50 bucks or so.
Have you checked to make sure your head is flat?
Or Seth, either one
Sorry for the delayed response, The gasket blew when I was running about 50* total ignition advance. It's my assumption that was the cause of the gasket faiure.
Or Seth, either one
Ring the heads and use wire loc gaskets .
yeah, OK :)sphss
I have to admit... I've had my share of drunk post's too. Got a 40 of Old-E in my hand as we speak :D
1 - 11 of 11 Posts
