x2On My Turbo Car, I run the Fel-Pro MLS...lots of the turbo community has great luck with them. I think they're a great gasket. My .02
you've gotta seal the head too, not just the block, the head chamber will be much bigger than the block boreok, i guess i need an education!...if a 468 is a .060 over, makeing it 4.311...why the big gasket (4.370)?...am i missing something?...school me!
FastRat
FastRat
Which is one of the issuses I have with the Titan ICS.The smallest bore the sell is 4.520, and that is a little bigger than I care to run if I don't have to.you've gotta seal the head too, not just the block, the head chamber will be much bigger than the block borebulb
yeah, i know what you're sayin, be nice if they made a set with notches instead of just round. gotta say though, their damn near impossible to make leak, we've ran my uncle's 3times already , just shoot alil copper coat on em. his tt496 isn't oringed so we run the ics gaskets on it. noone was able to make the block look near as nice as the heads so we didn't even try the felpros, big lack of nice machine shops in this areaWhich is one of the issuses I have with the Titan ICS.The smallest bore the sell is 4.520, and that is a little bigger than I care to run if I don't have to.
FastRat
Ask, and you will get the answer your looking for. Make statements like the one above, and you'll probably get more than you bargin for. I can't believe I let that one go. Must have been in a really good mood that dayi dont think u can put a 6.385 rod in a std deck block...i believe the piston will hit the valves..
FastRat
Dang Bob you must be slippin, everyone knows you can run a 6.385 in a 9.8 deck, but only with a 2.19" intake valve absolutely no biggerAsk, and you will get the answer your looking for. Make statements like the one above, and you'll probably get more than you bargin for. I can't believe I let that one go. Must have been in a really good mood that day![]()
You really didn't say that, did you?i dont think u can put a 6.385 rod in a std deck block...i believe the piston will hit the valves..
and you're just kiddin, arent you?!everyone knows you can run a 6.385 in a 9.8 deck, but only with a 2.19" intake valve absolutely no bigger SJ
Oh yea just pokin at GN7, whats up Scott been kinda quite without Mr Hat around.Originally Posted by FastRat
)eek
