1 - 17 of 17 Posts
custom member
anybody know where i can find a 1.800 exhaust valve for my dove heads... i guess they guy who set these up set them up with bigger exhaust valves and 3 are bent so i need new ones .. ive tried manley,miloden,ferrea and nothing.. any help
I use the Ferrea 6000 competition 1.800 in my Dove heads:|err:)devil
My Chevy 1.80's are cut down 1.88's.
Smokin low has it buy the balls,If you still have 3/8 valve stem diameter find a machine shop that knows what the hell they are doing and make a set of 1.88 valves to work, buy the time you do the math and try to find a 1.80 valve you will have missed a month on the water. Not trying to be a smart ass but I,ve been down the 429-460 road ALOT. M
How? 1.88 is larger than 1.80.........:)hand
I want to meet your machinest.
Name is Denny, Saum Engineering. :D
Same guy did an incredible porting job at the same time.
808 E Lincoln St, Wichita, KS 67211-3303, United States
Phone: (316) 267-1818
www.highflowdynamics.com
You first need to check OAL and Tip Length of the valves currently in your heads and then find a match, but generally:
  • Ferrera F6159, 1.800", 5.058" OAL, 0.250" tip (this p/n also works in a D3VE-A2A head as a +0.075" valve)
  • S-I 2101E-S, 1.880" (dia. must be cut to 1.800", as your lathe's cutting bit shrieks in pain), 5.073" OAL, 0.250" tip (this p/n also works in a D3VE-A2A head as a +0.100" valve)
  • S-I 2106SG-S, 1.800", 5.073" OAL, 0.350" tip (<---you might need +0.xxx" retainer)
1.800 exhaust, eh? Hope you're no bigger than a 2.19" on the intake side and don't have too agreessive a cam (big lift/dur with a tight LSA). Assuming bigger than RV cam, the general rule of thumb over here is 0.060" between the intake and exhaust valve heads...if you don't have that, then turn the heads or sink the seats a bit. By the way, in regards to your 3 bent valves, you might want to make sure that the reason for the bent valves is not relative to what I am discussing in this past paragraph.
LO
Oh, and one last thing:
How dare you photoshop your avatar into a negiative. For christ's sake stop messing with all of us and make it back into a full color image like it should be.
LO
1 - 17 of 17 Posts
