031
I have a Dart block and AFR heads. The 4 bolts/ studs that go from the block to the heads from the lifter valley weren't in the ARP stud kit. Anyone have a part #?
Some guy
I think Dart and ARP both make the kits. With a Dart block you may have to grind a bit for clearance, real good to check before you clean and assemble the bottom end.
Dart does indeed have a stud set for the four inner points. It is about 90 bucks. There is a stud that screws into the head...not just a bolt. Comes with a funky "U" shaped washer and a 12 point nut. If you are unable to find the dart p/n I will track it down.
try a p.n 64210240
Wags
