1 - 7 of 7 Posts
www.highflowdynamics.com
BBC Zoomies, Ford Engine Parts, Header Evac Kit, Blocks, Blower Intake, Stroker Kit
  • Rewarder Zoomies for BBC or Ford A460 heads, swept back, 2.25" tubes, ceramic/aluminized (or whatever) coating. Flanges sawed to allow individual cylinder installation & removal. Zoomie pics are in Post #3 below (scroll down). $300
____________________________________
  • Your common exhaust header evac kit, brand new. $30
  • Ford C9VE heads, bare, cleaned and magged, ported intake and exhaust, standard valve seat diameters, ready for machine work & assy: $550
  • Ford C9VE cylinder block, fresh tear down, std bore, sonic checked and deemed good to 4.44" bore: $350 with sonic check sheet
  • BBF 4.3 Stroke Rotating Assembly, will not be separated
  • Scat 4.300" cast steel crankshaft, cleaned & magged, fresh turn & polish 0.010"/0.010", perfect: ($275)
  • Brand new CAT 6.700" 4340 chromoly H-beam rods: ($350)
  • Brand new KB403-020 pistons for 4.38" bore, 30cc dish: ($400)
  • Internally balanced, with mallory slugs: ($175)
  • Compression ratio with 75cc heads: 10.2:1
  • Compression ratio with 95cc heads: 8.9:1
  • (Total cost to put it together: $1200)
  • Rotating assembly offered for: $---
4.300" Rotating Assembly is Sold
  • D0VE-A Block, 0.030" bore: $---
  • D9TE-AB Block, std bore: $---
  • Both blocks sold together: $---
D0VE and D9TE Blocks are Sold
Custom fabricated blower intake for Ford 429 460 engine with standard port configuration, ie, bolt pattern for the carbed heads with oval passenger car ports, Police Interceptor ports, or Super Cobra Jet ports, C8VE, C9VE, D0VE, D0OE-R, D1VE, D2VE, D2OE, D3VE, A429 Aluminum, SCJ Aluminum, Edelbrock, TFS Street/Strip (not A460), Blue Thunder CJ (not Thor), etc. This is an NHRA legal blower intake with SFI approved Blast Plate added (a $300 component, plus the machining and welding installation labor), injector nozzle ports (can be plugged), etc. The water exit passage is deleted for low distributor fitment (distributor/blower clearance) but you may plumb your own water line attachments if you are running water. This intake manifold worked excellently for us, just changing our engine program now. Based on overall design, fitment, and workmanship, this is among the nicest blower intakes we have seen for these heads. Asking $---
Blower Intake is Sold
All prices are "plus shipping." Personal delivery inside California possible.
Serious inquiries please call HFD directly if interested.
Thanks.
Lurker
Interested in the headers. Do you have any pictures available?
Rewarder zoomie pics
Rewarder Zoomie pics. Remember: the header tube flanges mount individually to the head so the tubes don't look symmetrical to one another until the pipes are mounted. Great Price at $300:
Cocoloco
I am interested
I need a 460 block or short block. Its for a run around jet boat not racing so a stock short block would be fine. If I have to rebuild this one I will need a block. Let me know what you have. I'm in San Diego so I can travel to pick up in Cali. Thanks
We do have numerous blocks to choose from, ranging from fresh tear down to performance prepped. And a block can be delivered in California, or perhaps we meet up somewhere. Short block and full long block are also possible. Please call to discuss the details of your current situation and I can better present you with an option or two.
1 - 7 of 7 Posts
