1 - 2 of 2 Posts
Hi Bob,
I have an 84 Eliminator with a SBC 350 engine currently installed. I have an older style glenwood exhaust setup on there now, with one intlet for water at the front, a tube that splits that incoming setup, then runs along the top to the rear of the log where the exhaust exits through the rest of the system.
I am looking at a set of new style headers with an inlet for each header tube for water access..
Could you provide any kind of help as to how I should plumb this? I have one water source coming in as of now, should I run individual braided lines to each exhaust tube with a fitting? Kind of new to me, and I'm not in a place where I can take a look at any other setups right now.
Thanks!
TECH EDITOR/TEST DRIVER
Can you tell me if the headers that you are about to install are water-jacketed or water-injected? It would also be helpful if you can provided a brand of the proposed header system.
Thanks
1 - 2 of 2 Posts
