Need a bit of help.
Here are the problems:
Here are the facts:
Here are the questions:
Trent
- Mechanical fuel pump with two fuel filters. One before the pump and one afterwards. The one before the pump has fuel but it is bubbling. The one after the pump is practically dry. Fuel pump is new and just in case of a weak diaphragm I replaced it with another new one. Generally occurs after twenty minutes of run time.
- Replaced mechanical pump with electric pump rated for 6 psi and every thing runs great for about 3 weekends. Still running two fuel filters. One before the pump and one after. The filter after the pump is dry and the one prior is full. Not for sure what the problem is, but I still have the mechanical fuel pump on the boat so I reroute the lines back to it, just to try and finish enjoying the weekend. The problem with fuel bubbling in the first filter returns. So I put the electric pump in line with the mechanical but no luck. I pulled the inline filters in the Holley 750 and they are clean as a whistle.
- While limping back to the dock (intermitting getting to plane out) motor begins running rough, won’t idle and the oil looks like a milkshake.
Here are the facts:
- Gate valve open fully since day one. (didn’t know I should adjust it)
- Used a turkey pan (didn’t know I wasn’t suppose too) Eldebrock Torker 455 intake
- Water temp gauge broken (so I have no idea what the motor temp was, boat is a project.. aren’t they all)
- 455 engine with Indmar log exhaust manifolds.
- All new plumbing hoses with excellent water flow when on trailer using garden hose.
- Berkley pump
- I have since take the motor out and tore it apart, but cannot figure out exactly where the problem occurred.
- Fuel tanks have been cut in half cleaned and welded up this summer.
- Generally never turned more than 3500 rpm.
- Do electric fuel pumps get weak diaphragms or do they just quit working?
- The turkey pan looks fine, would it be evident if it was the problem? Such as a rip?
- What temp does vapor lock occur? The engine never seemed all that hot.
- Any suggestions.
Trent
