1 - 3 of 3 Posts
I just pulled the Berkley water logs off of my Olds.455...had some exhaust gaskets to replace, right? Well, my starboard manifold is got a crack the size of....well, you know. The Manifold is toast, cracked, major deformation on the the center two cylinder ports.
I need this problem resolved in 2 weeks as I will/should be on Lake Powell.
What are my options for bolt on replacements without changing too much else?
Hardin Marine has these: Log Manifolds - 350-455 Olds - Hardin Marine
But I cannot find any riser that goes with these.
Anybody got a good used Berkley water log for the starboard side of a 455 Olds?
Thanks,
Kurt
You could check the parts for sale section for used,
or check with Tom at Jet Boat Performance - he often has stuff like this laying around.
1 - 3 of 3 Posts
