1 - 16 of 16 Posts
Floatin dirty
Actually, they are 1700. I think the guys name at Herring in HB is Jeff. I am on his email list and he does periodic demo testing at Elsinore for those that want to try Herring props. They are some of the best wheels in the industry and seem very professional to deal with. If you try one out and it is not right, I am pretty sure they will let you trade it in for another one.
mud slinger
That sounds more like you are buying it with an exchange.
Floatin dirty
I don't believe so, You may be thinking of the race cleavers which are more expensive. Their 5 blade bravo props are 1700 last time I spoke with them.
Hey Cliff,
Call DCB and ask for Tony. He did all the test work for Eliminator when he worked there. He will give you the optimum set up for your combination. He helped me quite a bit.
How does that thing run?
Hey Cliff,
IMO it runs great! 88-90mph full load (5 adults), I need to go out by myself and see what it will do. All around performance is awesome though.
Floatin dirty
You need to look at all variables such as mid range cruising speed. Typically, you do a lot of boating in the 4000rpm range. 5 blade props will usually give you better mid range speeds at the same RPM as a 4 blade. I run 60mph at 4000rpm with a 29" 5 blade and only 52mph with a 30" 4 blade at 4000rpm. Better speed and fuel economy also.
8 more mph at at the same rpm is awesome.
5 Blade is awesome! Just bought a 6 blade Hydromotive to try next. My "X" is pretty high though. Lower cruise rpm, higher top speed, BUT harder on the drive, if its marginal now, you will know it real soon. Make sure you've got a good, aftermarket prop shaft in there, or when it breaks, it and the prop will be at the bottom of the lake. TIMINATOR
Floatin dirty
You are right about being harder on the drive but it really comes down to how you operate your boat. No hard starts, keep it around 3500 till it planes out and don't cruise for long periods in the RPM range where your motor makes its peak torque. If the boat gets out of the water, gotta back off the throttle before it lands and that prop bites again. 6 blades is really gonna hook up. They are typically used in race application where you need low single digit slip performance. Cat hulls are fine with 12-13% slip for basic performance boating on the lake.
Boat Nut
I'm spinning 4 blade herring cleavers and Like it. We tried the 5 blade which gave great cruise but gave a bit too much stern lift at higher speeds which made us feel loose. Wish they would have worked as it was about 8 mph better cruise.
Call Julie at TUP...
She was blowing out some CNC props for Bravos for $500 and I beleive she'll have what your looking for...
Julie
Throttle Up Propellers
SAI
727-531-2255
40' of Skater
Is 12-13% pretty decent for Bravo stuff? I'm between 7-8% on my ssm stuff and Predator is lower than that, by a bunch! It's crazy to see it on the Livorsi gauge when Im co-driving with him. :)sphss We run 5 Axis props on Predator.........
Come to think of it, my 36 Spectre with Bravos was 10-11% slip.
Because KAP said so...
I have two Mercury Maximus 32" RH props for sale, one was labbed by Bblades diffuser cut down 1" and cut from a 15.50 dow to a 15 has about 15min test time on it and the other is a stock maximus 32 RH...PM if you want to give either one a try...
Floatin dirty
For mod tunnel hulls yes, V bottoms more around 10%. With your race boats and drives, you should be in the 6-8% range or even lower depending on how you have the #6 propped. Maybe the Spectre was a little more efficient also due to being a true tunnel hull. I am only referencing what I have read in the mags over the years like in the Teague write ups.
1 - 16 of 16 Posts
