1 - 10 of 10 Posts
32 DW X-CAT
I am 16.5x39 five blade 18 degree, they work great.
Comment:
How is the hole shot with the above prop you must be pushing some serious HP and/or running 1.5+- gear ratio. What drive do you have on the back can't tell from the photo.
HERING has a buy a prop(s) and you can swap it til you get the right one program. If so I will soon be a customer as well:).
KAP
It is what it is
I'm running 6 blades on mine. Since I haven't run anything else, I can't tell you if they work better or worse than anything else. They do seem to perform well all around, out of the hole, midrange and top end.
29812
Just rememeber they have a bite, a hard bite ....
and they are not cheap to fix or replace
herring
Comment:
KAP
the hole shot is good and I am running 1.35 gear ratio #6 drives. They did not have the exchange program when I bought mine. It was a 10k guess.
1 - 10 of 10 Posts
