Relative to pump gas, should not be a problem running 12 lbs of boost on 91 with intercooler and aluminum heads as long as timing is held no more then say 30/31 total. I have had Teague and GT roots motors in heavy boats that ran exactly 12 lbs on 91 pump gas. That said, you are a bad tank of gas away from a problem.... I always mixed some av gas in as a precaution. Current Teague motors run great at 12 lbs boost on 91 but they are large 5/8 litre Whipples which are more foregiving vs a roots blower, discharge temps are way lower.
The comment on HP being a constant relative to boost levels, that is not necessarily correct. Different air pumps will produce different HP results due to efficiency and discharge temps. Examples; I have seen a whipple screw type blower produce as much as 100 HP more vs a Roots at the same boost level. Same would hold true for some Centrifugals and certainly turbos, they are much more efficient as compared to a roots style blower. Roots blowers consume huge HP to drive them and their discharge temps are pretty high.
I have no input hi helix vs standard but I bet a call to Mooneyham/BDS answers that question.
Wow, news to me!! Thanks
devil
Leaving turbos and centrifs out of this, because there is no real argument that they will make more peak power than either roots or screws.
I always get a lttle chuckle out of the horsepower comparisons between the 2. I really like screws and would love to run one if I could. But the HP they claim is more than a little skewed.
There is pretty much one screw, whether it is a Whipple, Lysholm, or Keene Bell, they are all the same internally.
But when they test a screw against a roots, they test against a off the shelf POS cast rotor stage I roots, usually too small and spin the piss out it.
They ALWAYS test them cubic inch for cubic inch, and the roots is a loser on those grounds. Its not rocker science, the screw functions better at speed than the roots. '
They NEVER test dollar for dollar. They never test the screw against a Littelfield LB20, SIS/Kobelco Superman, or TBS XR, never with 18 strip rotors or hi helix, no retro bottom, front discharge or delta opening. Its always some off the shelf Weiand street blower that NOBODY actually uses.
Spend the money the Whipple costs on a roots, and the HP difference gets a whole lot less.
Like Edlebrock testing a dual dominator Victor Ram against a cast iron 2bbl manifold.
