As a rule you can get away with more timing at altitude.Could someone give me a base number to start with for holley jets size. I am running at 5100ft (vs San Diego) and it is so rich I get popping and very brown plugs.
Also is there any need to change the timing at this altitude?
Thanks
brown plugs is ideal air fuel mix.Could someone give me a base number to start with for holley jets size. I am running at 5100ft (vs San Diego) and it is so rich I get popping and very brown plugs.
Thanks
It pops through all RPM ranges, however it doesn't really start until about 1200 and gets progressively worse. I took it to Lake Almanor which is 4505 alt and I got about 300 more RPM's. The popping was the same however. It also wants to(will) stall if I get out of the throttle too fast. It will cough and sputter, but can sometimes be saved if I flutter the gas.exactly what rpm does it start to pop? exactly what rpm does it stop? my suggestion would be to check everything. popping can be caused by a lot of different things, ignition related or fuel related. and it can be ignition related and not manifest itself until rpm is raised under load (don't ask me how i know). possible problems are mostly easy fixes once you figure it out, but it's not necessarily a good thing to run it that way.
92 LBS is less than ideal.....violent11
I took it out today and got the same thing...
So I decided to check the compression while I was sitting on the beach. All cylinders w/in 2lbs of each other @ 92lbs on one compression stroke. No problems there.
#7 and #8 plugs looked "oily" or perhaps sooty.
Pulled the scoop and filters and looked like hell in the carbs Black soot on EVERYTHING. Sprayed some carb cleaner all in it.
pushed the throttle and noticed that the rear carb was not sprayingbulb
Cleaned it out, had some gasket material blocking it.
Fired it up and remarkably better throttle response(of course) but still popping
Checked the cap for wear, nada, it has maybe 3 hours on it.
Decided to rotate the wires 1 place so I could get more advance than before, (tunnel ram hits the cap) wouldn't start. Went to put the wires back and noticed that #7 and #8 were reversedsphss
I must have checked the firing order 3 or 4 times since this started and each time missed that. WTF I feel stupid.
Got in started and idled perfectly. Mashed the gas and5250 RPM's and a hole shot I never dreamt of having; only had a worn out impeller before.
It did stumble a bit after maybe 30 mins of lake touring with my family just before it went on the trailer so I may have some junk in filters, but I think problems are solved for now.
Crank until peak pressure is achieved (typically three or four revs). 120 shoud be really close.Where should I be? It will hit 120 on the second stroke... never really cranked it for multiple revolutions to see where it tops out.
