1 - 10 of 10 Posts
I have a customer that is forced to use a dead head regulator. I have never ever used one but know there are some now that flow well.
Any recomendations? -8 in and only need 2 -8 out.
1 or 2 with dual carb 700 HP gas?
race pump reg!
Ron, I have the race pump dead head reg on my boat. # 8 to the reg with 30 psi, 2-#6 and one smaller(to the nos) at 10 psi. seems to work fine.
Holley 12-704.
The 12-704 is 1 in and 1 out reg and will easily flow twice your requirement. It will require some sort of tee arrangement for 2 dual feeds. The 12-707 is a 1 inlet (-10), 4 outlet(-6) all for o-ring AN fittingswith a black ano'd billet body. Its twice the money but easier to plumb and a little cleaner depending on the application; like 2 dual feeds.
Why not one of the race pumps regs?
Race Pumps
Another excellant reg. and a decent price. with 1, -8 inlet and 2 -8 outlets.
GN already answered...but one os plenty. They make a two port, and a four port. I'd say if you're going to use a fuel manifold of some kind, use the two port, or plumb the four port directly to the carbs. They're bigger than you might think (both the same size basically)
The two port on my leeetle burro Pepe' ;)
The four port on the blown 489
senior member
The 12-704 is 1 in and 2 out reg and will easily flow twice your requirement. It will require some sort of tee arrangement for 2 dual feeds. The 12-707 is a 1 inlet (-10), 4 outlet(-6) all for o-ring AN fittingswith a black ano'd billet body. Its twice the money but easier to plumb and a little cleaner depending on the application; like 2 dual feeds.
  • Regulates from 4-1/2 to 9 PSI
  • One 1/2" NPT inlet and two 1/2" NPT outlet ports
  • .437" (7/16") restriction
  • Includes mounting hardware and AN style fittings
  • Alcohol compatible
  • AVAILABLE FOR PURCHASE holley website info
    Price: $93.55
  • ................ holley website info, i have one & it works fine with the mallory fuel pump that i run .it has the bypass on the fuel [email protected] 250gph,i run @ 925 hp -1050 hp
    Price: $93.55
Your right! I stand corrected. Inlet in the bottom, 2 outlets on the side. Thank you for the correction Turbo.
Bang for the buck, the best reg out there, and replacement parts are readily available. Rebuilt kit is 5.99.
The reg is available from Summit for 90.00 and comes with the AN fitting for the in and outs
1 - 10 of 10 Posts
