No way on earth! There isn't such a thing as a 12 degree strut for a flat. It would never work. No way and no how. And, if there was, it would be such a crappy strut that you would not want to put power to it. (The more power, the stronger the strut needs to be.)
Take an angle finder and measure the strut and then measure the flat part of the boat right next to the strut to figure the true angle of the prop shaft. That is the only angle that we care about. A 12 degree v-drive does not make a 12 degree prop shaft angle. The only thing that matters is the degree of the prop shaft to the bottom of the boat. And there is no way it is 12 degrees. The boat would fly to the moon with a go cart engine.
We want to propel boats forward. But, to do so, we need them to handle. A portion of our power needs to elevate the boat out of the water so we don't plow like a tugboat. The degree of the strut is that "attitude" to get the boat out of the water. Big power circle boats want to be between 7.4 and 8 degrees.
If the strut is correct, and the right dimension from the back of the boat (meaning the prop is in the right location and at the correct angle) it doesn't matter if you have a 10 degree v-drive box, a 12 degree box or an 8 or 7 degree box. All the Casales are the same in basic strength and that type of thing. (Cuz if the shaft under the water is correct, the degree of the box only determines the driveline.) If your strut is correct and you have a 12 degree v-drive, and you don't want a drive shaft with u-joints, your engine will sit up high in the boat. Big deal, unless you plan on racing in circles. Or, put u-joints in the driveline and set the engine down further in the hull. I guess there really isn't much advice I can give until I know the true strut angle and the quality of build and material.
Once we get that, we can tell you a little more.
