Striegel built BBC oil pump. Shimmed spring. Pick up braced and brazed. Pick up built for use with oil pan that comes with the pump. Only used for initial break in and and pan was used when the motor was painted. Pan i believe is an 8 quart. Motor ran 100+ lbs of oil pressure on initial start up and maintained about 80 once warmed and idling.
125 plus the ride.
125 plus the ride.
