Paul, yes always have oiled pump for winter. Thing is I ran it in the shop last weekend and it was running weak on one side. So watched some tutorials from Andy at Hillborn. I had to reset the throttle blades and a hex link adjustment as one bank was opening more than the other. I made the 5/16 gauging material that Andy used to set the proper clearance. The pump is wet, then pulled the fuel line to the metering block. I believe there should have been more fuel than there was. A little skitchy about pulling the front pump cover as I lost a pump doing that years ago. I'll dig into it this coming week. Thanks for your input.
