1 - 5 of 5 Posts
1. BBC square port standard deck Edelbrock Victor Ram. 660 holleys, dual feed bowls, rear metering blocks. Phenolic spacers under each carb. Braided lines, 4 port regulator. Enderle linkage. Dooley scoop with spark arrestors. Ready to bolt on and run. $1200. 2.SOLD!! River Rat / Kuhl water pump set up for Jesel belt drive. BBC $450. 3. Brodix 2+ heads. Complete with T&D shaft (1.7) rockers. Pushrods and head bolts included. $2500. 3. Crane R274 roller cam and lifters. .737I, .726E. 274 @.050. 28 passes from new. $300. 4. Comp Cams BBC roller cam. .775I, .748E. 284, 292 @.050. 112 LDA. Like new. $150. 5. Edelbrock Square port Victor Jr. Dominator top, standard deck. Like new. $175. 6. Ultradyne BBC roller cam. .810I, .782E. 114 LDA, 290, [email protected] $150. If you need something that's not listed, just ask. I might have it! 414-750-1917. Pete.
intake
1. BBC square port standard deck Edelbrock Victor Ram. 660 holleys, dual feed bowls, rear metering blocks. Braided lines, 4 port regulator. Enderle linkage. Dooley scoop with spark arrestors. Ready to bolt on and run. $1200. 2. River Rat / Kuhl water pump set up for Jesel belt drive. BBC $450. 3. Brodix 2+ heads. Complete with T&D shaft (1.7) rockers. Pushrods and head bolts included. $2500. 3. Crane R274 roller cam and lifters. .737I, .726E. 274 @.050. 28 passes from new. $300. 4. Comp Cams BBC roller cam. .775I, .748E. 284, 292 @.050. Like new. $150. 5. Edelbrock Square port Victor Jr. Dominator top, standard deck. Like new. $175. 6. Ultradyne BBC roller cam. .810I, .782E. 114 LDA, 290, [email protected] $150. If you need something that's not listed, just ask. I might have it! 414-750-1917. Pete.
can you post a pic if the intake?
1 - 5 of 5 Posts
