Thanks. I'm gonna pull the bowls on my carbs tomorrow and want to know if the jetting has been messed with. Plugs are pretty black looking.I wanna say 71 & 80's with power valves...but let me check.
Wow! the jets are nearly the same With a pv? weird.75 front 76 rear and a 8.5 power valve
Nope...Not even close IMHO.....And an 8.5 power valve? is there really that much vacuum with dual carbs? Wow! I would never have guessed that high.
Thats what I was thinking too. Maybe thats why the plugs look black? Motor seems to idle good, but it is new to me, so I think I may try a lower number pv and just see what happens. Course I dont even know whats in them now, I'll find out in the morning. Still seems weird that the primarys and secondarys are so close to the same with a power valve installed.... But sure enough, the Holley web site says 75 and 76Nope...Not even close IMHO.....
GThand
I'll bet I end up with a setup like you are discribing by the time I'm done messing around with it-70 or so in the primarys, and maybe 76-78 in the secondarys. This is a fairly mild motor. Just seems more logical to me to have all four holes flow the same at WOT.Yeah all specs I come up with say the same thing.
We always wound up with 71's pri with power valve and 80's in secondary with no power
valve. Guess that is what I was thinking.
Some guys did 80's square with blocked power valves.
Only the front had a power valve stock.
Depends on which metering block is used too, there are many different blocks and the size of the PV ports vary. My guess would be a very small "Power port".Thats what I was thinking too. Maybe thats why the plugs look black? Motor seems to idle good, but it is new to me, so I think I may try a lower number pv and just see what happens. Course I dont even know whats in them now, I'll find out in the morning. Still seems weird that the primarys and secondarys are so close to the same with a power valve installed.... But sure enough, the Holley web site says 75 and 76
Yeah, I guess changing two things at once wouldn't be to smart. I'll mess with the power valves before making any jet changesDepends on which metering block is used too, there are many different blocks and the size of the PV ports vary. My guess would be a very small "Power port".bulb
In a dual toilet app.I would go for a 4.5 or so PV to start with. (closed longer).
devil
GThand
