1 - 10 of 10 Posts
Just realized the D9TE block I am switching to has an oil filter adapter designed for a truck with an oil cooler.
My old block(D1VE) just had a spin on filter.
How am I going to put a filter on this thing?
Am I going to have to put a remote adapter on it?
If yes, please point me in the right direction(part # maybe).
Not a clue how to approach this.
Unscrew the cooler adapter and switch it out with the filter adapter.....
That made too much sense.:)bulb
Ok, I never said I was smart...:)sphss:)sphss:)sphss
The filter adapter on my D1 block looks pressed in, so I suppose I can buy one that will fit this block?
Thanks futs.
Bostick Racing Engines
It's threaded on both ends... just need to get it out without dinking up the threads... an inside pipe wrench dealy-o works pretty good. If you wish to just get a new one... I believe they are still available from Ford.
chevys have a hex cut in the insert to remove them. Im assuming the fords do to. Look inside and see if you can get a allen wrench in there and get it off.
Ok, I'll call Ford in the morning.
Simple enough...
Early ones [68-69 and maybe 70] had a hex, 7/8" or 15/16" I think.
www.highflowdynamics.com
Simple enough...
Actually, not that simple.
If you tell most Ford parts counter guys that you want a filter adaptor for the 460, you'll get the male-to-female version just like the one in your D9TE cylinder block. And when you ask for the male-to-male version instead, they'll tell you that there isn't one.
That's because the male-to-male adaptor wasn't used on the production 460's since 1978 (33 years ago).
When you walk up to the parts counter, ask for a male-to-male oil filter adaptor for a Mustang 5.0 302 small block. It's exactly the same as the one you're looking for. Which year 5.0 Mustang? I dunno, a late 1980's or later, I suppose.
LO
p.s. The OEM adaptors originally had a 1/2-inch round ID. Chances are that you'll get such an adaptor but with a 7/16-inch hex inside in order to facilitate install. I'm not a fan of that smaller dimension but it's just a technicality in the case of most builds. We normally offer a really nice radiussed filter adaptor with a round ID (0.500"+ dia.) and radiussed exit, but we are currently out of stock and don't know when our supplier will have the part again from which we make them.
Thanks Paul.
Helpful info, as usual.
1 - 10 of 10 Posts
