Just put my junk back together(from the broken rocker deal) and no sparky sparky. I have juice to the hei, not sure if it's the coil or the module. Just curious if this is something I can check at home.
Thanks.. I pulled the cap she's on there all right, dist. isn't 180* out, firing order quadruple checked. But no spark? I think god hates me, whatever you do don't anyone name your boat the cash eliminator.lol Maybe I'll try a different ground, I would think laying the plug on my header tube would do it.if i read your post correctly you are running an hei distributor? if so make sure that the spade connector is actually on the male terminal coming from the coil. i have seen this many times where people get the connector wedged between the male terminal of the coil and the plastic housing of the cap. when this happen it feels like it is connected on the male terminal, but in fact is not.
this is a very simple easy check before you start replacing stuff.
AP
x2Put your tongue on the wire and crank it over.![]()
Spill it!! What you do? Tack to + power to tack?My boat runs now guys.....I'm a dumb ass. Fwiw, how do you check a coil?
I didn't have the other 3 wire connector hooked up right....my bad.x2hand
