1 - 20 of 30 Posts
031
I made 4 nitrous passes at Elsinore. Changed bottle after every pass. I finally got around to weighing by bottles and it seems that I used 5 lbs. on every pass. Is that possibe on a 10 second run? They are 10 lb. bottles. 24 lbs. full & they weigh 19 now. Oh yeah, It's a 250 shot. I'm gonna hafta have the old lady follow me up & down the river in the pontoon boat with extra bottles.
sounds about right to me, i could empty a 20lb bottle in 4 passes with my 450hp shot:D a 10lbs bottle may have gotten me 2 full passes, and 1 pass on just the 1st stage.
it sucks doesnt it;)
Charts I have seen say 4 pounds per minuite flow rate PER 100 HP LEVEL.
250 shot = 10#/min flow rate.
How much nitrous in one pass? Enough to laugh your ass off!:D
You will get 2 full runs to one bottle. It will die out at about 5-600 ft on the third.:)
River.. plate or fogger ?
What was your best pass et/mph?
S CP :D
B1 Racing
Rich, 5 lbs. per pass does not add up to the jets your running. I'm running much larger jets and cant use anywhere near 5 lbs. per pass. Are you sure they were full? Did you get carried away when purging?
Fogger. Best pass 9.80 @ 106.6
Shaun, I'm paying 5.00 per lb. in Havasu
Good job. :)grn
Were the Nos passes from end to end of the track ?
Did they have any 660' info ?
S CP ;)
031
Discussion Starter #20
Good job. :)grn
S CP ;)
Yeah, I launched with it.
660 -- 99.118
1188 - 102.272
1320 - 106.635
I did weigh my full bottles and they are only at 22 lbs. so I probably didn't use as much as I thought. 3 lbs a pass is more like it I think.
1 - 20 of 30 Posts
