i have a 63 hydroflite hydro. front is tunnel opening but it is flat across the back. it is a 19' and almost all vdrives ive seen have cav plates. id like to add to help keep nose down since im new to these boats. placement and install are my main concerns and then locating used parts is next. thls for help
With hydros u already have 2 training wheels up front? ;)
Post a pic of this hull. This dosent sound like a right application here tho.......
Merry Christmas btw :)
Hydroflight hydros back in the day dont think they used any cav plates but alot old shovels had a pc of 2" x 2 " angl on the back
wilkes will set ya straight
MY HYDRO
Boat Test GURU
Hydroflight I will check my photos and see if they had any plate set ups. I think Mouser is right. My friend
Barry Bollman and Barry Burkus owned the Hydroflight molds before the Charger boat guys acquired the tooling.
U can call me at 714 540 8908 and I will go over how I would attach the plates to the hull. I always wanted
one of those boats.
JW
Sponson Extenders
I had a 19 Kindswater Hydro and back in about 1972 Harold sold me a pair of sponson extenders that bolted to the inside of the sponsons and extended about 5 feet back. They had like a meat clever 8 or 9 inch extension hook in the front then tapered down to about two inches in the rear. Helped get the back end of the boat up and made it ride on just the rear tips and bottom 1/2 of the prop with only about a 6 or 700 hp motor. The object of a hydro is to get it out of the water and run on the 3 points.The boat worked a lot better after I put them on. Didn't turn worth a darn but thats not what hydro's are about. Eddie Hill has a Sleekcraft Tunnel v-drive he put a plate on and put about 3 pages of instruction on this forum a couple of years ago. My buddie has the same boat and we are piecing a system together with Eddie's spec's right now.
Canoe Jockey
It almost looks like you have a cleaver prop...they do not work well with inboard steering and not recomended.
