The pump is junk, throw it in the lake and go get a mech. pump, carter, holley, what ever flips your trigger and put it on there and go have fun for several years without any more bull shi--.
The pump is junk, throw it in the lake and go get a mech. pump, carter, holley, what ever flips your trigger and put it on there and go have fun for several years without any more bull shi--.I need help with an electrical issue. My electric fuel pump just started blowing fuses. It is a Holley Red with maybe 15 hrs on it. I took it out and cleaned it all out, hooked it to a battery directly and it seemed to stick at first. Then after a couple taps it started again, every time. I reinstalled it and turned the key, it spun for about 10 seconds and it blew a 25A fuse. replaced the fuse (20A) and popped again. I tried aluminum foil around the fuse(ghetto, but I didnt have any more fuses) and it came right on but I felt the foil getting hot very quickly.
Is there any way to test the pump to see if it has an internal short? Is the 25A fuse too small?
Please help so I can get to the lake tomorrow. Thanks
I can't tell you how many mid 80's/early 90's Camaro's I fixed with INOP door locks, clock, cigarette lighter, power trunk release, console box light... because of a penny a child stuck in the cigarette lighter...... auto style cigarette lighter port installed at some point and it is the cause for the short. Unplugged it and all is good
As far a running a relay, I am a little confused as my weakest point on my boat is the electrical. Does that mean you run a wire from the fuel pump directly to the battery with a on/off switch somewhere in the middle? If so I assume this switch has a "relay" to the front which controls the current flow?
Assuming again this is correct, is there an inline fuse to protect the fuel pump?
Well I went and got a new one, plugged it in and popped the fuse.
I read up and found that the pump only draws 2 amps so I knew there had to be a problem somewhere. I checked everything I could think of then on the last thing found the problem. This boat had an auto style cigarette lighter port installed at some point and it is the cause for the short. Unplugged it and all is good
A standard ignition switch should be more than capable of handling a electric fuel pump on your type of boat with no relay's.
Most boats don't have a fuse for "just" the electric fuel pump, but that doesn't mean it should be unprotected.
He said the fuel pump draw's 2 amps, I'd like to hear your opinion on why a relay is recomended.I could not DISAGREE more with this statement.
AP
