Have you tried backing out the mixture screws a little bit more on the primary side, and make sure the idle feed restrictor passages in the metering block are not plugged up. It may be too lean on the idle circuit, which can still play a part at only 1500 rpm as it may not be pulling good fuel from the main metering just yet.
Of course make sure your transfer slot/throttle blade is set up correctly.
