1 - 20 of 35 Posts
Any guesses? Going on the dyno Tuesday.
532 ci, Dart Big M, 4.60 Mahle pistons x 4.0 Scat crank, 10.6:1, 6.535 H beam rods.
AFR 305's ported to 325cc, 2.325 valve, 400cfm @ .700"
Ported Super Vic intake with a QF two circuit 1050, no spacer.
55mm custom Straub hyd. roller, .750+, 260's @ .05
Morel .903 hyd. roller lifters
7/16 Smith Brothers pushrods
1.65 Crane gold rockers and AFR stud girdles
MSD crank trigger
Stef's kickout pan.
General consensus is - if it had a 4150 instead of that junky old quickfuel it might make some steam.:)coffee
That the best you can do? :indifferent0001:
I think later this year we'll be doing a TT version of this engine.;)
why no spacer ?
hood clearance ?
280 Profile Cat W/575sci
My new motor has a quick fuel carb. I am not familiar with them...what is the drawback?
At what RPM's should the HP guess be?
That's the $64 question with this one. I have no idea what it'll pull given the valve train. We're doing something with the .903 hyd. lifters that I don't think has been done yet. I intend to pull well into the 7's, just not sure what it's going to do. Has a lot of spring pressure. "Target" peak power should be in the 6800rpm range.
Happy Easter Scott.
If you are going to run it that hard it could be worth another 25 from what I stated. the heads are good for 840+ just not sure what the hyd roller is going to do. ..... I'll revise based off your rpm range and say 835 +/- 7.5 hp ( so a 15 hp range)
edit: a spacer would be worth 10 hp on this deal ...... so revise again.... 825 +/- 7.5 hp. ;) final number
Discussion Starter #17
Happy Easter Scott.
Thanks Jon...happy Easter to you.
FWIW, made over 900 with a lot less cyl head. We'll see. If the lifters can handle the cam and springs, this thing should rock pretty good.
Discussion Starter #19
Aside from some available manifold issues, which I'm sure you can deal with, have you any plans to try a set of AFR 300 oval ports on a similar build?
No.
Platinum Member
MSD crank trigger
Stef's kickout pan.
Nice job !
I am sure it will do very well :)devil
I will be interesting to look at the torque curve #
1 - 20 of 35 Posts
