1 - 9 of 9 Posts
When I get on the it, The belt to the alternator flies off. I figure its when I punch it. Anyone got a better bracket belt combo Idea. Any suggestions or pics will be appreciated.
Write now I have a notched "V Goove" belt with standard automotive type pulley's. The engine is a 502 BB chevy. One wire Alt.
TEN THIRTY ONE
Sounds like your pulley are not aligned with one and other. It doesn't matter what bracket/mounting system you have you need to make sure this is correct or you will pitch belts all day long.
Visually, they look to be in line. I'll have to take a measurement.
chrome alt pulleys like to chunk belts too;) if your pulley is chrome, ya might do some good scuffin it up with emry cloth, that is if your alignment is straight and its still chunkin belts
The Pulley at the crank is chrome. Dam near didn't get me home:D. I'll try that too
Lay a long straight edge across the face of the crank pulley and see where it lines up with the alt. Sounds like an alignment issue.
Does your alternator have little cooling fan blades on it? My chicky has a 600 hp sand jeep that used to throw a belt every time she goosed it. It turned out that the alternator was reving so fast that the cooling fins were warping at high rpm and actually pushing the belt off. We just changed the size of the alternator pully so that it wouldn't rev so fast and problem solved.....Just something to look into....
Boat Nut
Put a larger pulley on the alternator, They don't need to be zinged like that, frees up a little HP too.
1 - 9 of 9 Posts
