Hello! I have a 427 in my Sanger Hydro with a tunnel ram and two new 600 Holleys. Runs great but have a problem with the motor idling. Haven't played with the carburetors at all except to make sure float bowls are full. Checked for vacuum leaks and none. I have to play with accelerator peddle in order to keep running. When I let off of it and idle comes down it dyes. I'm running at 5psi on my fuel pressure. Was told to run a piano wire in the holes on carbs to allow more fuel and less air. Not sure if this is the way to go? Even had problems with a single carb on the motor. You have any ideas? Steve
