Your result's may vary ,but this chart has been very close over the year's for several engine/pump combo's that my brother and I have owned. The engines were a 710 HP 512" Ford our 780 HP 565 Ford and the re-done 565 that made 855 hp. All three ran nitrous 200 to 300 hp system's and the chart was accurate within 150-200 rpm's or so.
I also used this chart with three friends to dial in the boat's after they had dyno'd their engine's all three were within 200 rpm's. Two of them were 650 HP 502 Chevy's.
This chart will not work with an MPD fully blueprinted pump I learned that this past Summer. The MPD impeller will read a little over one size smaller than this chart shows. His "B" will perform like an "A" on the Chart
Please remember this chart is actual HP "Observed" not "Corrected" . If you dyno'd your engine on a 75 degree day and you have "corrected" numbers of 700 HP at 6,400 rpm's it won't (I'll repeat) it won't make 700 hp at the river on a 105 degree day. It will probalby be at least 15% off if not higher, which means it will be at least 105 HP less than the corrected dyno numbers.(Sorry that is more like 15% from the corrected numbers not observed. More like 7% off the observed numbers)
I'll reserve edit's:
Sleeper CP
Big Inch Ford Lover
Sleeper CP
Big Inch Ford Lover
