1 - 3 of 3 Posts
small member
impeller.jpg bought a impeller kit for a bravo 1. i have the pump off and ready to install. should the impeller be larger than the hole on the housing?? i have to squeze it in.
Yes. I usually put the impeller on the shaft first, the press the housing over it while turning the driveshaft clockwise. A bit of dishsoap for lube helps.
I put a large zip tie around the fins and tighten it down. Once I get the impeller half way in, I cut the zip tie off and push it all the way in. Definitely use the dish soap though.
1 - 3 of 3 Posts
